Thanks for that. It’s not C00143214 as I had one of these and tried it. Is it possible you can give me part numbers for the other two? I will go back and check serial number.
Yes it is indesit, sorry my mistake. Just one more question. When i put C00255860 in connections it tells me no longer available use C00259736, will this module work for all models regardless of serial number?
Not sure but according to the limited info on Partfinder the ‘high pressure sensor’ has been removed on the later Wuxi made dishwashers. That seems to be the only reason for the change in PCB.
Partfinder is updated online every week or so and there is no mention of it being superceded on that yet.
C00259736 is still listed as available at Masterpart.
