just wondering if anybody has identified which components on the module are causing this fault code. yes i know its meant to be the thermister and yes i check the wires, but on occasion when the module is at fault do you know which bits?
keithwilliams wrote:just wondering if anybody has identified which components on the module are causing this fault code. yes i know its meant to be the thermister and yes i check the wires, but on occasion when the module is at fault do you know which bits?
I suspect you may be the ideal candidate to sign your name up for THIS then? 💡
