Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint/Indesit F05 Error Codes
- This topic has 10 replies, 3 voices, and was last updated 2 years, 6 months ago by
simonb.
September 9, 2023 at 8:16 pm #102222
simonb
ParticipantHi all,
Were getting quiet a few of these coming through, apart from the obvious blockages/pump, does anyone know what seems to cause the lack of feed to the pump in cases where its not related to drainages or defective pumps? i had put these down to the pcb but due to how many were getting can it be caused by other components? ie pressure switch etc
ThanksSimon
September 9, 2023 at 9:14 pm #487991electrofix
Moderatoron what type and range of machines ?
September 9, 2023 at 11:20 pm #487992simonb
ParticipantHi Dave,
I never anticipated it would make a difference per model or range of Hotpoints, i will get a few examples of the models were struggling with at the moment tomorrow, they all behave in the same way, drain intermittently then the feed stops to the pump, they throws up f05, continuity across the pumps, absolutely no blockages… iv even swapped the pumps thinking the impellor might be sticking….
Simon
September 9, 2023 at 11:35 pm #487993electrofix
Moderatoryou dont even say if its a dishwasher , washing machine or washer drier
September 12, 2023 at 10:54 pm #487994simonb
ParticipantHi Dave, its a washing machine F05 usually blocked but some are not getting a feed to the pump
SimonSeptember 12, 2023 at 11:25 pm #487995electrofix
Moderatorassume its not a washer dryer as the dryer ntc can cause problems
have you had a close look at the board. dont know if pump uses relay or triac
September 17, 2023 at 11:25 pm #487996simonb
ParticipantThanks Dave, were going out to another one of these this week, i will take a good look at the pcb this time…
SimonSeptember 18, 2023 at 6:17 am #487997matrixresonator
ParticipantWasn’t it these machines that sometimes needed pressure switches recalibrating after a blockage? Something like a couple of litres of water added to the drum with it power off then turned on and set to drain.
Might be worth a try.September 18, 2023 at 8:12 am #487998electrofix
Moderatorsome of them did yes
add a few liters of vwater, set to drain and let it finish the progamme
but he pump has to start to effect this and i got the impression in this case it doesn’tDave
September 18, 2023 at 8:47 am #487999matrixresonator
ParticipantYeah, just wondered if the PS was playing up thinking it was empty it might no fire the pump up.
September 18, 2023 at 11:57 am #488000electrofix
Moderatormatrixresonator wrote:Yeah, just wondered if the PS was playing up thinking it was empty it might no fire the pump up.
correct some of them only turn the pump on if they think there is water in the drum so its a valid observation. its all to do with saving the planet
