Hotpoint Indesit Tumble Dryers Scrape after fitting drum sup
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Indesit Tumble Dryers Scrape after fitting drum sup
  • #44229
    neilsukwg
    Getting a few call backs on these which scrape after fitting a complete Drum support kit.
    Sometimes the drum will only scrape once machine is hot, which tells you how fine the tolerance is between drum and back panel.
    Has any one devised a fool proof method for doing this job right, first time every time? (apart from selling new one)
    I have tried variations on number of spacer washers fitted, and always ensure every screw on the machine is tight as the cabinets are so flimsy.
    Any ideas or pointers to threads covering this topic much appreciated.
    Neil
    #280266
    silverbroom
    Re: Hotpoint Indesit Tumble Dryers Scrape after fitting drum
    Hi Neil,
    Try the search facility and put in the model numbers of the various t/dryers you have been repairing, you should find plenty info including drum mods and rear seal mods etc.
    silverbroom
    #280267
    helo_75
    only cure is a new drum
    1703662 for the vented
    look at the back panel when u take it out, its probably been scraping all the time
    #280268
    A1engineer
    is there not a mod out for these that you fit an extra washer between the support and the backplate, which pushed the drum further from the back panel???
    im sure in the v4 shaft kits a new washer is there and thats what its for.
    #280269
    The extra washers don’t cure a bad one, as helo says the modified drum with the rounded edge at the back is the only certain cure.
    jonnieboy
    only guaranteed complete repair is new drum and new back panel with the tear drop style bearing
    no more scraping noises after that 😀
    ofcourse after that mod you then get the drum falling off the front suppport because once the front is stripped down a few times it likes to bow outwards
    #280271
    Sadly the teardrop bearing wears away just as fast as the old square one. 😥
    Teardrop Explodes, even…… 😀
    :p45:
    #280273
    DDSDDS
    i hate these dryers take out half a dozen screws and the entire appliance is like a flat pack from ikea
    #280274
    trotter
    Bit harsh on Ikea?…….considering there flat packs are a pile of S4!l
    #280275
    neilsukwg
    There must be a way, and god dammit I aint gonna rest until I find it come hell or high water!! 😡
    You aint got the better of me yet you poxy scrapin vtd’s!
    feel better for venting my feelings, a mans gotta scrape by somehow,
    drum up some business and dry to do his best at all times.
    maybe I need a couple of days off 😕 ❓
    #280276
    helo_75
    erm, if your feeling, erm , a bit dodgy
    look where its been scraping, and use the back seal out of the kit, and stick it to where its been catching
    not that ive ever done that, you understand
    #280277
    Knee in the middle of the back panel and pull works for me……….
    robbra
    Don’t ya just love the technical solutions forthcoming on these pages? 😆
    but they normally work better than the official cures :rolls:
    Rob
