Hotpoint Indesyhte drum lifters
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Indesyhte drum lifters
  • #48611
    maltheviking
    Been to a Hotpoint WF556 with the welded drum.
    I fitted three new lifters, customer tells me that it has had seven since new,18 months old. 😳
    User has not been washing trainers or leaving coins etc, so pretty obvious that he is using the machine correctly 😕
    What he did point out was that the lifters only come off if he is using a prog. with the 1600 spin, dosent happen at slower speeds.
    Has anyone come across this?
    #297141
    chezza
    Re: Hotpoint Indesyhte drum lifters
    They never ever ever ever wash trainers :rolls: 😆
    #297142
    maltheviking
    chezza wrote:They never ever ever ever wash trainers :rolls: 😆
    This pair are an elderly couple 😉
    #297143
    helo_75
    for sure, there will either be something in there, or the locking tab will be broken
    there is a mod, to help the paddles fit tighter, makes me giggle everytime i read it
    #297144
    maltheviking
    helo_75 wrote:for sure, there will either be something in there, or the locking tab will be broken
    The only thing I took out was a bra wire the size of Wembley 😀 It hadn’t been in there long. The paddles started to break off from when the machine was new and under gtee. , customer phoned Indeshyte and they just sent out new lifters but no engineer to fit them, so there is a chance that the customer did not fit them well, although the tabs were in A1 condition.
    helo_75 wrote:there is a mod, to help the paddles fit tighter, makes me giggle everytime i read it
    Any chanch of you enlightening us O wise one 😉
    #297145
    franz
    If I remember correctly the memo says – serves you right you should have bought a Bosch
    Franz
    #297146
    Flyman
    If the plastic lugs are all broken off then definitely something between the drums. Normally a bra wire is enough to do it. (and they come in two’s you know! 😆 )
    #297147
    Micky 32
    Maybe overloading?
