What specs are neede to install a Hotpoint C367EXH dble oven.
It looks like it has two live wires and 1 nuetral, 1 earth?? Is 30AMPs enough?
I have it wired up and it half works, except for the timer and the hobs. And the lights for the ovens are on even though they are not switched on themselves??
With all due respect, if you are asking these type of questions, you would be best advised at getting someone who is qualified to check and connect for you.
If you go to the repairs@ page this will guide you to a local engineer who should be able to help.
With all due respect, if you misconnect interms of capacity or in terms of functionality you may end up causing a fire or personal injury.
Whoever connects up should carry out some basic electrical testing to establish earthing and to inspect that your Main Equipotential Bonding is correct – this is for your protection.
