been out to this machine
Not finishing program
Fitted connections pattern element
All ok
3 weeks later same problem
Fitted another pattern element
Call 1 week later same problem
Could the n/t/c be causing this or are they just dodgy elements
What is wrong with the element, if it is O/C then I would suggest cheapo element to blame unless the heater is coming on with no water in the drum due to PCB or pressure switch fault, if it is the wash element you are talking about of course.
