can anyone help? hotpoint intergrated dishwasher
bc145 17702616 called to this about a week ago
base full of water and float switch activated, sorted this
out and all seemed well. it now sounds as if it has done this again.
will have to drag this out tomorrow and would be glad of any tips
as i havent worked on one of these before…..
thanks
Check on this machine, if its got the overflow straight into the base from the tub, and can cause motor problems. You will see the overflow in the base stands about an 1 1/2 inches high.
This can be caused when the filter gets blocked or when using 3 in 1 tabs (supersoft water) raises water level.
Overfill situ, straight into base and usually enough to soak the motor.
As Indesit / Ariston.
I’ve seen a few Indesits which did this because they were leaning forward far enough to just tip a little water down the twin overflow pipes at the front. Sometimes it was sufficient to activate the FPS. When it wasn’t it would just slowly rust out the motor. Who designs this stuff? 🙁
