Re: hotpoint leaking
Seal can leak, usually when drum front has been removed and refitted without replacing with a new seal, something I do every time I have the drum front off.
On later models two extra clips were added at about five to and five past the hour to prevent leaks from this area.
On more than one occasion I have had leaks from this seal caused by solid objects getting into the drum. Also the drum front can crack where the heater slots into the drum front.
