Re: Hotpoint LFT 04 problem …..help appreciated!!!
The only way to find out is to remove the mains plug and carry out a visual inspection, if that fails then a megger or multimeter will be required to test the appliance.
Its 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Indesit so is of rather poor construction, the wiring in the door is very weak, the main PCB in the base fails quite often as does the heater and main circulation pump.
