Hotpoint LFT 114 still leaking after new seal fitted
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint LFT 114 still leaking after new seal fitted
  • #73841
    philip5660
    Hi All,
    At my wits end with this dishwasher as I’ve replaced the LED card (as it was completely dead) after which I fitted a new door seal as there was steam and water pouring out the top.
    The new seal has helped in that there is no longer water dripping to the floor but there is still some steam escaping out the top which is damaging my worktop.
    My next thoughts are to replace the door locking mechanism. Is this wise?
    I really don’t want to spend much more on it as it’s had very little use and quite honestly it just seems to be poor quality tat.
    #388949
    DrDill
    Re: Hotpoint LFT 114 still leaking after new seal fitted
    It is poor quality tat,
    Has the door itself been bent against the hinges?
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #388950
    philip5660
    I can’t see any evidence of any bending – How would I tell apart from looking?
    We do have a crazy 5 year old who frequently abuses the kitchen doors so it’s not beyond the realms of possibility.
    #388951
    DrDill
    And that could be the problem, poorly fitting door that quite possibly caused the led failure
    Sent from my iPhone
    #388952
    philip5660
    That could be.
    I’m not sure how to proceed now. I suppose I could end up replacing door and hinges and latch running my total bill to date up to that of a new dishwasher!
    #388953
    madangler1
    Is it absolutely level ? Iv seen so many door issues relating to level is madness. Is it sitting on a tiled floor, are the feet on blocks or pieces of tile?
    These machine are very flexible and if they are not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} level with all feet set correctly the door will not close correctly and the seal will leak as the cabinet is twisted.
    Iv had an ongoing machine where its sitting on various pieces of tile and wood. Although it looks level it just twists the whole cabinet, if I pull it out into the middle of the room on the solid floor its perfect but once in the whole it just won’t sit correctly.
    #388954
    philip5660
    10 points to madangler1 !!
    I attached a magnetic spirit level to the inside at the top and sure enough it was off, I straightened it up and it’s so much better!
    There is still a very small amount of water condensing under the bench but my wife thinks there always was. In any case it has started to delaminate anyway so I’ll be putting something on it to protect it.
    For our uses I hope we can get another year out of it anyway – cheers!!
    #388955
    DrDill
    Put some aluminuim tape on the underside of the worktop.
    Sent from my iPhone
    #388956
    philip5660
    I was thinking that might be appropriate – I’m glad you confirmed it.
