Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › hotpoint LFT 114 UK
- This topic has 5 replies, 2 voices, and was last updated 10 years, 11 months ago by
Charlie777.
May 6, 2015 at 10:31 am #84871
Charlie777
ParticipantHi
iI am new to this site and wonder if you could help me ???
I have a hotpoint LFT 114 UK dishwasher and last night
the washer went awol.the drain pump runs continuously and the power and eco buttons flash rapidly even if i turn the power off at the wall and turn it back on 60 mins later !! I have flushed hot water through the bottom of the machine,
cleaned the filters and still the pump runs and lights flash,the waste is draining into the sink etc,if i hold down the 2 buttons in any sequence it resets for a few seconds and then starts flashing again !!!!
the buttos that flash is the power button on the far left and the eco led button no 1?? on the left. Hope you can help thanks charlieMay 6, 2015 at 1:21 pm #427042iadom
ModeratorRe: hotpoint LFT 114 UK
The base is flooded, you have an internal leak somewhere which needs investigating and rectifying.
May 6, 2015 at 2:13 pm #427043Charlie777
ParticipantRe: hotpoint LFT 114 UK
Thanks for replying,have you had this problem before ???
i will check it out tonight !!May 6, 2015 at 2:18 pm #427044iadom
Had it before, 😀
This is a low end Indesit dishwasher, leaks, dodgy electronics, main pump failures, heater faults etc, etc. :rolls:
May 6, 2015 at 10:56 pm #427045Charlie777
New update,I have removed washer and taken side off and tilted washer on its Bach water drained out from somewhere had a general mess about checked all pipes/drains clear hoses /seals all seemed ok.re assembled machine re connected and all seemed ok,put it on a cycle and washer worked fine !!! Until drain time…..all water drained….then the pump just continues to run with power button and first button next to it flashing quickly….any ideas ????……it seems to me once the wash is done and the pump has emptied the machine the pump is not getting the signal that the machine is empty of water and to go onto the next stage !!!! Thanks charlie
May 6, 2015 at 11:00 pm #427046iadom
You have a leak somewhere inside, you will find the base has filled with water again.
