Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint LFT 114 won’t turn on
- This topic has 5 replies, 2 voices, and was last updated 3 years, 5 months ago by
andy-uk.
October 12, 2022 at 7:04 pm #101248
andy-uk
ParticipantI have a problem with my Hotpoint LFT 114. It suddenly just stopped turning on. Checked the fuse, it is fine. I already ordered another dishwasher yesterday, because I though as it is probably quite old call-outs wouldn’t be a good idea, but when I took it out from underneath the worktop and it suddenly started working. I though it was connected with a new fuse, which I’ve just installed, even though the old was was proven working, but when I pushed it all back under the worktop, it stopped turning on again.
I took off the front panel, nothing seems fried, but I don’t know what else to try. Really or how to access any other possible culprit areas. Any ideas as to what might be causing it to not turn on at all, but then it did come to life a few consecutive times, when it was outside.
Again, I’m not sure if calling someone out is a great idea as I doubt there are any spare parts available any more and call-outs are quite expensive.
October 12, 2022 at 11:33 pm #484005electrofix
Moderatorfirst thing i would check is the on off switch itself
had a few of these fail but if you strip the box open, find the switch and use a very small amount of wd40. the push the sw on and off a few dozen times you can often get them to work againalso have you checked the socket its plugged into is ok ?
October 18, 2022 at 9:52 am #484006andy-uk
ParticipantThank you so much for this! It was the on/off switch indeed. It seems to be working again now, hopefully it lasts a while! Thank you!
October 18, 2022 at 4:49 pm #484007andy-uk
ParticipantActually it’s still very temperamental. Is there any way to but this button panel somewhere still?
October 18, 2022 at 5:05 pm #484008electrofix
Moderatorandy-uk wrote:Actually it’s still very temperamental. Is there any way to but this button panel somewhere still?
and in english this means ?
if your saying can you get the panel then it looks likely but they are about £50
DaveOctober 20, 2022 at 9:44 am #484009andy-uk
ParticipantSorry, it’s just turning on/off inconsistently, sometimes it takes 20-30 presses for it to work, sometimes it works immediately. Have found the buttons module on ebay, hopefully that will do the trick.
Thanks!
