The machine starts and then flashes (left to right) 3 led’s. It fills then faults. I’ve looked through the error codes but I haven’t found the ones relating to this range of super quality machines. :rolls:
Turbine fault is usualy the turbine, there was a problem with the early ones you have to change the the whole unit it comes with, i’ve fitted 4 now for this fault never been back to one after fitting, JJ
