Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint LFT04 error – eco button flashing
- This topic has 8 replies, 3 voices, and was last updated 14 years, 1 month ago by
teecee86.
March 6, 2012 at 9:25 pm #68304
teecee86
ParticipantI have 2 yr old Hotpoint LFT04 Dishwasher that has developed a problem. When you start a wash you hear water pumping out, then it starts to fill. Water is sprayed from both of the arms and they both revolve however there is a grinding labouring noise that sounds like it’s coming from the bottom of the machine. The water also drains out ok and I have cleaned the filters. On a full length wash there was error code of a flashing eco light (4th from the left). Can you tell me what this error code is?
March 6, 2012 at 10:16 pm #370528iadom
ModeratorRe: Hotpoint LFT04 error – eco button flashing
Light 4 is supposed to point to a heater fault, the noise sounds like a faulty main circulation fault. Both very common failures on this low end Indesit made appliance I’m afraid. 🙁
March 27, 2013 at 8:31 pm #370529Malyon2001
ParticipantRe: Hotpoint LFT04 error – eco button flashing
Similar to my problem. How do I fix it?
March 27, 2013 at 10:21 pm #370530iadom
I’m sorely tempted to be brutally honest and say buy something better. 😥
Remove the mains plug and check the heater for a start.
March 27, 2013 at 10:47 pm #370531Malyon2001
Water seems to be heating up ok..
March 27, 2013 at 11:03 pm #370532iadom
Main circulation pumps also fail for fun in these as well. 😥
March 28, 2013 at 12:46 pm #370533Malyon2001
OK. So, if it’s that, how do I fix / replace it?
Thanks!
March 28, 2013 at 3:11 pm #370534iadom
Is it still under 5 years old, if so then the labour only ( parts free ) option from the Indesit Company may be your best option.
The motor alone is around £95.00. 😥
Motor is accessed from underneath, be sure to remove the mains plug if you intend to go further.
March 29, 2013 at 11:34 pm #370535Malyon2001
Sounds complex.. It’s a fitted machine so I doubt I’ll be able to get underneath it..
