Hotpoint LFT114 dishwasher Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint LFT114 dishwasher This topic has 3 replies, 2 voices, and was last updated 15 years, 5 months ago by Shortwave. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts December 4, 2010 at 10:59 pm #59357 ShortwaveParticipant When the dishwasher has been off overnight (with the door closed) it has started to operate with what sounds like the pump running continiously. On opening the door the “Normal” LED is flashing. December 4, 2010 at 11:07 pm #337923 iadomModerator Re: Hotpoint LFT114 dishwasher Its best to give the flashing lights by number from the left. If it is light No1 that is flashing then you have a leak into the base of the machine. The machine needs to be unplugged, removed from its housing and inspected for internal leaks. December 5, 2010 at 8:43 am #337924 ShortwaveParticipant Re: Hotpoint LFT114 dishwasher Hi iadom, Thanks for the quick reply. The flashing LED is the second from the left, December 5, 2010 at 2:00 pm #337925 iadomModerator Re: Hotpoint LFT114 dishwasher Light 2 flashing = Inlet valve, connections, valve letting water pass through when off. Sounds like a faulty inlet valve. Valve leaking into machine, overflows into base, trips float switch and switches on the drain pump. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
