Hello. I own a hotpoint LFT114 dishwasher which developed an error no2 (led 2 is flashing after self-test). According to the service manual this has to do with the “charging electro-valve” which is broken. As far as I can understand this is the water inlet valve, right?
Now, I just dismantled the machine and it looks like it fills with water to the point it has to fill. When the motor pump is about to start I can only hear a hum (i guess it comes from the motor) and nothing happens. When I was doing the self-test, for the third time, the motor started to work and finished the test with no problem although the error code kept coming. This happened at least 3-4 times. The motor was working properly. So I put the machine together, filled it with dishes and started a full circle (my thought was that debris was clogged inside the motor and gone after the self-tests), but nothing. After filling with water the motor started to work for almost a second and then stopped with the strange low hum. Any advise???
Thanks in advance,
Nikos
