Just wondered if anyone can help me with a problem i’m having with a hotpoint lft114 uk
s/n 709211220
The first 3 lights from left to right started flashing during a cycle with the drain pmp running even when the door was open, I put the machine on again and the same happened and then the third time it went through a compete cycle which has ruled out a leak which is what i originally thought the problem was. I have googled this appliance and havn’t been able to find much info on it so any help will be gratefuuly received.
cheers
rob
3 lights flashing is supposed to signify a turbine fault. The water turbine, is registering a fault. Could be wiring fault, dampness on the turbine, PCB fault etc.
