hotpoint LFT228A
  • #73587
    rolf
    Hi folks .Went out to a Hotpoint LFT228A dishwasher today.
    Come up with error 5 could anybody enlighten me on this error code . Machine started washed for a couple of minuites then emptied and filled again a few times. I blew down pressure pipe and tried again, machine worked fine!!! I’ve got a feeling it’s not going to be the last I’ve seen of this machine. So any pointers before I inevitably go out to it again. Thanks.
    #388058
    HotDog
    Re: hotpoint LFT228A
    Look for broken wiring in the door common problem
    #388059
    rolf
    Thanks Hotdog . I’ll keep that in mind . Do you know what error 5 specifically refers to . Ta
    #388060
    Pressure switch.
    Mesh plate, filter or microfilter, pressure switch, circulation
    pump.
    Main circulation pumps do fail quite often on these.
    #388061
    rolf
    Thanks for the replies. I did recieve the dreaded call she says it worked for a few washes then the same again.
    I’m asahamed to say I refered her to Hotpoint because it was a call on the far side of the moon , it was a built in bodge and most of all I just didn’t fancy a pig and a poke at it. 😯 .
    I’m going to give her a ring next week to see how she got on . I’ll keep you posted.
