Re: Hotpoint LTF 11M132. Not starting no fault codes.
Tried door switch and it checks out also wiring isnt broken.
Also found on another search a self diagnosis mode where you power on and off and hold P button for 3 seconds and is supposed to start testing each component but all seemed to go as planned but failed to start on closing door.
Apparently the fault did rectify once but failed after 3 uses and not worked since.
Check pump was clear also and gave wiring the once over.
Should a fault code just show up on LED or is there a mode to check stored faults.
