Hi folks,
For the past few days, my Hotpoint LTF 8B019 dishwasher is stuck on a single programme. In fact, I can’t even switch of the dishware. The power button and the P (Programme) button do absolutely nothing when I press them. The only button that does anything is the timer button on the right. Oddly, this only powers off/on the dishwasher, but otherwise does nothing. When it was working correcrtly, the power button would function as normal and I could cycle through the different programmes by pressing the P button, but nothing appears to work at the moment. The rinse aid light is also constantly on, but the rinse aid is full. I understand this can take a number of cycles to clear, so might not be an issue. Just thought I would mention it.
I have tried powering off at the mains for 30+ minutes to see if thise will somehow force a reset of the controls, but no such luck. Is there some other way I can do some sort of factory reset or does this look like a new control board is required or something? Really appreciate any help. Thank you!
