Hotpoint LTF04 Error Codes
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint LTF04 Error Codes
  • #72532
    Liquid Tuna
    Hi, wondered if someone could help me? I’m getting the standby light and buttons 3 and 4 flashing. The dishwasher appears to be working normally when it actually switches on – fills, drains, heats the water etc and no bad noises. Many thanks.
    #384805
    Re: Hotpoint LTF04 Error Codes
    3+4 is a communications error, bad connections or breaking wiring between the main pcb in the base and the control pcb.
    #384806
    Liquid Tuna
    Thanks for the quick reply. Explains why it works after repeatedly pressing the buttons and shutting the door. Is it economical to repair?
    #384807
    It may just need the connector plugs tightening up or if it is a slight break then that could be easily repaired.
    It is an Indesit after all, not known for robust construction, the components and the wiring connections are rather flimsy. :rolls:
    #384808
    Liquid Tuna
    Yes I’ve been reading around on here and realised it isn’t actually a very good unit and seems to have a few known faults. Disappointing really. Still, I’ll have a look at what it could be and see if I can fix it somehow. Thanks for your help, I appreciate it.
