Hotpoint LTF8B019UK
  • #93408
    Hollytree_Technical
    Hi all
    This dishwasher is randomly over filling (most likely to happen when hot), most of the time when it fills it fills perfectly but every so often it will overfill without warning, during this time there are no error codes and the pressure switch has activated correctly, I have also checked that it is draining properly before each refill and there are no insulation resistance faults.
    If it was the turbine I would have expected it to error out but as it isn’t I am wondering if it is a board fault.
    Thank you
    Jem
    #454244
    TheSpinDoctor
    Re: Hotpoint LTF8B019UK
    Do you have the commercial code of the appliance please? It is probably an air chamber built up with fat.
