Hotpoint main PCB reprogramming
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint main PCB reprogramming
  • #97690
    Mpw785
    i was hoping someone can help me I have a few Hotpoint main circuit boards and have no idea what models they have been setup to run, does anyone know where I can get the equipment to reset the boards so I can either use them or sell them on.
    Kind regards
    Michael
    #469039
    kaibart
    The short answer is no because Hotpoint have so many variations on the same looking pcbs without a model number it is near impossible to do yourself
    #469040
    As Kai says it not something thats worth doing
    to be able to sell the boards on you would not only have to match the model number you would have to match the commercial code as you can get the same model with different software. you would have to be able to power the boards up and have not only the programming equipment but access to the correct firmware for the machine your trying to fit it to
    Its not worth it unless your doing the job as a professional and even then its doubtful
