Hotpoint mains cable/filter – problems
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint mains cable/filter – problems
  • #31024
    MickGeorge
    Does anyone know if these are giving a problem? Part No C00203264 m/c model WF100
    Went to one a couple of month’s ago tripping ELCB and tested down to earth.. fitted new cable/filter asy.. had to go back today to change part again as same thing..
    Just wondered if anyone else had problems.. are they just cheapo rubbish or might there be something else causing the fillter to break down to earth in such a short time..
    Comments appreciated.. thanks
    Mick
    #229410
    Re: Hotpoint mains cable/filter – problems
    Not had a single one with this problem Mick.
    hotpnt
    hi, you’ll prob find the filter is fine, its the plug that shorts out, just cut off & replace
    #229412
    wilf
    I’ve replaced a couple.
    wilf
    #229413
    Good tip about the plug then, thanks hotpnt. 8)
    MickGeorge
    Yes.. good tip..
    They are not like the usual molded plug lead where you can disconect the lead from the capacitor/filter so next time I get one I try that first..
    Mick
