Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Hotpoint Minstral FF72P PCB part PTC1?
- This topic has 7 replies, 8 voices, and was last updated 20 years, 8 months ago by
tttonyyy.
August 6, 2005 at 10:44 am #11139
tttonyyy
ParticipantHello,
Had a problem with my fridge section getting warm, so I replaced the thermistors with ones bought from here but this didn’t fix the problem (well, at least I have a spare set now!)
Eventually tracked the problem down to this device (top, middle) on the control PCB:
It’s marked PTC1.
It’s in line with the fan and was getting hot and cutting out (I assume a thermal resettable fuse). Chances are it went faulty went the fan iced up a few months ago.
Anyway, all the markings are missing from it so I don’t know what to replace it with. I’m hoping someone here has a circuit diagram for it and can tell me what part PTC1 is rated at.
For the time being I’ve replaced it with a 500mA quick blow fuse; the fan motor surges to about 230mA when starting and then runs at a steady 170mA.
Kind regards,
Tony
August 6, 2005 at 11:56 am #144082Dave_Conway
ParticipantRe: Hotpoint Minstral FF72P PCB part PTC1?
Unfortunately that information isn’t available as Hotpoint will only show/replace the entire PCB (no component level repairs 😕 ).
But….. I do have an earlier PCB here with what appears to be the same PTC although there are no positions shown or any markings on the component.
If you want the PCB you can have it, PM me your address and I’ll post it to you, just drop a donation to Children In Need to cover the postage 😀
August 10, 2005 at 8:53 pm #144083admin
KeymasterRe: Hotpoint Minstral FF72P PCB part PTC1?
That’s very kind of you Dave, but given my old one was tricky to remove and came out in three pieces I think I’d be better off guessing the trip rating and fitting a brand new PTC. They seem a bit delicate. 🙂
September 2, 2005 at 12:28 am #144084andy2
Hi Tony
The device PTC1 is probably a thermistor (Positive Thermal co-efficient) these work opposite to the usual NTC (negative thermal co-efficient) thermistors like the ones that you replaced on the evaporator.
As the temperature of the PTC increases so does its resistance, thus limiting the current that flows to the fan. As they often exhibit a steep rise in resistance the current to the fan will be negligable above a certain temperature. If the current increases above normal (as in a stalled fan due to ice buildup) the PTC heats up and shuts down the fan.
Your PTC was probably faulty shutting down the fan too early.
This type of thermistor is used in place of compressor starter relays to shut down the current to the start coil after the initial surge has started the motor thus preventing the start coil from burning out.
Andy 😀
June 28, 2008 at 11:54 pm #144085Tristan
I’m currently diagnosing an intermittent issue with an FF92 where the fridge compartment sometimes maintains ambient temperature whilst the freezer is at its expected -22°C.
In investigating the problem and reviewing the various threads here I discovered Tony’s question about PTC1 on the control PCB and, although his question was a long while ago, thought I’d record some useful information here for others that might need it.
Based on the current draw Tony reports I suspect it can be replaced with RS 198-848 PTC over-current thermistor,15R 234mA which has a trip current of 330mA and costs approximately £1.44.
October 18, 2010 at 1:50 pm #144086RickT
Rs 198-848 is now discontinued and replaced with 191-1816
December 18, 2010 at 10:52 pm #144087Don-44
Thanks to all for this post – Confirmed all the work I’ve done
Freezer at -22 Deg, Fridge at room temp
Replaced both the Green and Yellow thermistors in the back of the freezer to no affect.Shorted out PTC1 and all’s well (make sure you switch off before doing this, it’s 240v)…ordered new part as above from RS.
By the way PTC1 is at the top of the board (if you just lift the panel up with wires still connected) next to the display PCB..mine was grey but not all are. It is marked on the boardGood check is to leave the fridge door open for 5 mins, then on closing, check the fan runs for a minute. (i.e. until the thermistor gets hot)
Thanks guys.
November 24, 2013 at 6:20 pm #144088Carlo1971
Hi All,
First time using a forum, hope I am posting this in the correct place. I have a Hotpoint FF92S which the fridge section is staying at ambient but the freezer is working fine at -22. I have read various threads through this forum and managed to isolate the fault to the PTC on the control PCB. I read in a post that the PTC can be shorted out to confirm that it was faulty. I did this in the same method that what mentioned, using some 5amp fuse wire and shorting out the PTC legs. I put the fridge on to run waited for about 20 minutes or so for the freezer to come down in temp. Once the freezer reached -10 I opened the door and to my satisfaction I finally had cold air coming up the tube and in to the fridge compartment. I thought great, I can now order the PTC from RS and the job will be done. I left the short on the PTC as did the guy who put the post on but after about a couple of minutes from opening the door there was a pop. On investigating I could smell the dreaded burning smell of a component failure and found that TY5 has popped on the PCB. It comes of one of the legs from the PTC and I assume it is altering current flow when the PTC’s resistance is changing. The markings on TY5 are Z7S Y150 but I am unable to match it with anything? Can anyone help as to identifying this transistor? where can I get one or an alternative? Thanks in advance for any help. -
