Hotpoint mistral
  • #36601
    jongriffin
    mistral 8596 cant get the evap fan to run.
    changed thermisters ,checked gas pressure,changed pcb.
    Fan will run if the fridge door is opened and then shut but only for
    about 30secs.Any ideas!!!
    Jon
    #251630
    johnnyj
    Re: Hotpoint mistral
    Fan motor itself, not common but tripped me up a few times it will run on test, also once temp comes down it will run for a short while then cuts out and will not come on again, i assume you have made sure the door is making the door switch.
    #251631
    jongriffin
    yeah tested door switch and is ok.
    The fan works on test and after the doors been opened for a bit then shut.
    Maybe ile change fan and see.
    Thanks for the advice.
    #251632
    Dales-Electronic
    And finally check the thermistor in the fridge baffle area, these are generally very reliable but they do control the fan together with the freezer area sensor.
