Hotpoint Mistral
  • #66101
    robbra
    Model FF71P ser. 72153908
    This is my F/F and the display has started reading FF(definitely not EE as stated in the fault codes) and when the fast freeze buttton is pressed it shows -34deg. I’ve turned it off at the wall and will wait to see if it’s a build up of ice as the freezer door wasn’t closed properly a couple of days ago. If this doesn’t work what’s the answer?
    Thanks.
    Rob
    #363052
    wizard
    Re: Hotpoint Mistral
    FF is Fast Freeze. Somebody’s pressed it! It’s showing -34 cos it’s been running on fast freeze. Give it a chance and it’ll warm back up eventually aslong as you don’t have it on FF again. Wiz
    #363053
    robbra
    Thanks Wizard,fingers crossed. Have just switched it back on and it says 18c.
    #363054
    robbra
    Gotta say Wizard, on reflection I was a bit thick 😳 Put it down to a blonde moment 😕
    It’s working ok now.
    Rob
