hotpoint mistral 8596 fridge compartment erratic temperature
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum hotpoint mistral 8596 fridge compartment erratic temperature
  • #64859
    tonypr
    Help,
    The Temp on the fridge keeps shooting up intermittently to
    +15 degrees and above.I have cleaned out all the coils in the bottom etc,but suspect it may be a loose connection on the pcb or the evap thermister.however how the ***k do you get the rest of the back off to access this. Ok I know the thermister is in the lamp doings. 👿
    #358320
    kenlawred
    Re: hotpoint mistral 8596 fridge compartment erratic tempera
    The problem is most likely the evaporator thermister situated to the right corner of the freezer behind the covers,yellow in colour.
    #358321
    tonypr
    Total frustration here, how do you access the pcb and evap thermister short of taking a hacksaw and drill to the upper back panel.I have accessed the compressor compartment from the back but no pcb.Hair getting pulled out here, HELP.
    #358322
    tonypr
    Read loads of posts on this appliance, now have all info I need.
    Thanks for the reply. 😀
