Hotpoint Mistral 8596P door hinge and spacer rings
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hotpoint Mistral 8596P door hinge and spacer rings
  • #8183
    Simon46
    Can anybody tell me the part no’s of the hinge on RHS middle of fridge (between upper and lower doors).And also the spacer rings that fit on the hinge and if they come seperate or in packs of.
    Hinge appears bent downwards and lower door is catching on plinth and upper door is barely catching light switch.
    Simon
    #127202
    Re: Hotpoint Mistral 8596P door hinge and spacer rings
    Hi Si,
    Centre hinge is 2600425 @ £6.83 list – can’t find the spacers at all.
    Simon46
    Cheers Chris. Will see what washers are at B&Q.
    S
    #127204
    Seamy
    Got this problem recently, spacer washers are included in Hinge Kit Assy, but you can also buy the hinge on its own, or washer on its own! washer Htp’ Part num’ 2600385, i think about £2.30 ea, Electrue code 5031681105406.
    #127205
    Simon46
    Thanks Seamy. Already ordered seperates. Did not know you could get a hinge kit. So ten seperate washers equals about thirty quid. How much is the kit, and does anyone know how many washers do you get with it?
    S
    #127206
    Seamy
    If you use Mediator on Electrue connections online you can search for list of parts on most Hotpoint & other makes, this i find very useful an invaluable resource for getting part numbers & price quotes etc.
