Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Hotpoint Mistral FF72 Fridge Freezer
- This topic has 8 replies, 3 voices, and was last updated 19 years, 8 months ago by
dotcom.
August 7, 2006 at 2:11 pm #19741
dotcom
ParticipantI have a Hotpoint Mistral FF72 fridge freezer which is about 6yrs old.
The issue seems to be when i put the Freezer under load it stops freezing, i.e the fans cut out and it goes very quite. the display shows it going from -22 and gradually rising in temperature, obviously the fridge section starts to rise as well.
By unload i would have just put in some food into the freezer at ambiant room temparture and trying to freeze it. If i hit FF this makes no differance.
I turned off the unit and cleaned it out, hoover’d all areas etc.
i noticed that the fan located in the bottom was not running. if i remove the none frozen items after a while it starts to freeze again.
Any help would be required.
Note, i have started a new topic, as i did post a similar reply to the bottom of another Hotpoint mistrale issue.
Regards
Carl.
August 7, 2006 at 2:17 pm #184360Simon46
ParticipantRe: Hotpoint Mistral FF72 Fridge Freezer
Do you mean the fan in the freezer compartment? Type in Mistral in the search facility. Plenty of info there.
Regards
SimonAugust 7, 2006 at 2:30 pm #184361dotcom
Simon
Thanks for the response,
all fans seem to stop as it goes completley quite, but the fan in the bottom of the unit as the back seems to stop as well.
The compressor gets very hot as well, is there a thermal cut out.
I have looked on the forum for other issues, and there are lots. but i cannot seem to match my symptoms with other posts.
Carl.
August 7, 2006 at 2:37 pm #184362Simon46
It will do a periodic defrost. Cracking noises as ice is melting. How long is it off for? And have the thermistors been replaced yet. Unplug power if you are going to have a look yourself.
Regards
SimonAugust 7, 2006 at 3:02 pm #184363dotcom
Simon
No nothing has been replaced as yet, it is not off for long. i have removed the front covers inside the freezer comparment and it did have ice in there but not loads.
Carl.
August 7, 2006 at 4:19 pm #184364Dave_Conway
Is the condenser fan (the one near the compressor) never running ?
If it’s not, that is the problem 😉
August 7, 2006 at 8:12 pm #184365dotcom
no this does run, but when the problem happens it is stopped, i am not sure what drives the fans, as this seems to be the issue.
What is the trigger for the fans is it the thermostats ??
And why when the freezer starts getting to warm does everything seem to stop. It is almost like something over heats and a thermal fuse cuts out.
carl
August 7, 2006 at 8:47 pm #184366Dave_Conway
If the fan isn’t running the compressor will cut-out (overheat) especially in the recent weather we’ve been having 😉
It may be the motor itself that has failed ?
August 9, 2006 at 5:07 pm #184367dotcom
The fan does run, but the issue seems to be it all stops running once under load. however as i have nothing in the frezzer at the moment both are running fine. But as soon as i put some warm food in the frezzer it will stop working again.
