Hotpoint Mistral FF80PR freezer not getting cold
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint Mistral FF80PR freezer not getting cold
  • #68748
    Kenn8
    Hi All
    I have a Hotpoint Mistral FF80PR, I have recently cleaned and defrosted it (including the compressor and coils), the fridge that is working with temperature fluctuating between +3 and +7. It’s the freezer that’s the problem the temperature fluctuating between -10 and -7 it will not drop any further (it still freeze). You can hear and feel the compressor and fan working, I have switched off the appliance for 24 hours, but no change. I believe it’s a defrosting or Thermistor problem, can anyone help.
    I think Don from UK Whitegoods is the person, if so could you tell me the part, its costs and shipping details, any help appreciated.
    Thanks for reading
    #372653
    johnnyj
    Re: Hotpoint Mistral FF80PR freezer not getting cold
    There are 2 fans in these a condensor fan and an evaporator fan, which fan is running if it is the the condensor fan you will probl’y need a thermistor or evaporator fan motor.
    #372654
    Kenn8
    Hi johnnyj
    Both fans are working, you can feel the fan in the freezer compartment circulate the cold air to the fridge compartment.
    The problem is the freezer temperature fluctuating between -10C and -7C it will not drop any further, I have read that the freezer temperature have to reach -16C before the cold air circulation fan will properly regulate the fridge temperature. Thats why the fridge is working with temperature fluctuating between +3 and +7 (around the set temperature of +4C)
    If it is the thermistor, which one is it? There are 3 Yellow, White and Green.
    Or is it a defrosting problem, constantly on a defrosting lopp?
    Thanks for replying
    #372655
    Kenn8
    Help
    I have changed both the yellow and green thermistors, but this has not made any difference, Freezer stops at -9c will not drop any further, but fridge has gone up to +8c.
    Any help on the next step??
