Hotpoint Mistral FF92
  • #34611
    Auntie
    Having changed the thermisters back in September 07 because of a warm fridge,with great help & advice and great parts service, I now find over the last 3 months the temp in the fridge has gone up again twice.
    Reading the threads, I defrosted the freezer and found a large lump of ice at the bottom right hand corner, cleared it out, ran like a dream for two months,this morning fridge +5, looked at freezer -22 as always, checked inside freezer again iced up again.
    After the last defrost everything ran normal,is this the way it is to be every couple of months a defrost or is there something which is on the way out, ??thermostat.
    Any help would be very welcome 🙂
    #243320
    MarkPC
    Re: Hotpoint Mistral FF92
    Have you checked that when you replaced the thermistors that the freezer compartment thermistor is located infront of the back panel and not behind it. The thermistor feeds through a hole in the right of the panel when reassembling. I found in the past that if the thermistor is at the back the freezer tends to form ice blocks between freezer and fridge.
