Hotpoint Mistral Fridge Freezer FF92P – fridge not cooling after thermistors replaced
I’ve read through all the posts I could find and there’s nothing about the fridges not working after changing the thermistors,
I’ve replace the 3 thermistors in the freezer compartment behind the white panel, which cleared the (E2) error display that i was getting and cured the over freezing problem in the freezer.
The freezer is now reading aprox -22*c and the fridge is constantly around +19*c
From what I can work out it seems that the main fan in the lower freezer compartment which from what I can work out is the fan that blows cool air up into the fridge, is not functioning. It works for aprox 4 seconds when powering up the appliance so I can’t see that the motor is broken, any one got any idea of what to do next? The flap in the fridge behind the light works if a as it lifts and closes on power up and stays open after that, also the thermistor in the light fitting works fine too, any help/ideas much appreciated
James Wood
