hotpoint mistral plus 9596 fridge warm
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum hotpoint mistral plus 9596 fridge warm
  • #14437
    mav12
    hi all i have read the posts for the warm fridge problem with the mistral but i am gettting a bit confused .
    the fridge has stopped working freezer is fine .
    the fan at the very bottom of the unit on the right hand rear is working
    the fan in the freezer compartment near the top at the back is not working
    it spins for a short while when you power up then stops
    does this sound like a thermister problem .
    i ask this because another poster replaced the thermisters and still had the same problem of the fan spinning for a short while .
    is there any way of checking the thermisters is it possible to bypass them to to see if it is them causing the fault. i am pretty sure the ducts are clear
    the door switch is ok as in the light goes out when you close the door
    many thanks rob
    #159464
    Simon46
    Re: hotpoint mistral plus 9596 fridge warm
    I would replace the Evaporator thermistor first. Unplug power if you are going to have a look yourself :zap:
    Regards
    Simon
    #159465
    mav12
    thanks for the reply simon is it possible to test the thermister with a meter
    would this fault cause the fan to start for a few seconds then stop when powering up
    it only seems to d othis with the door open
    door shut the fan dosent start
    thanks
    rob
    #159466
    Simon46
    You could test thermistor with meter but you would not know the resistance values at which temperatures the thermistor is at. The fan will do that as it is in a test routine if power is applied with the door open.
    Replace the thermistor. Or get a man who can at Repairs@.
    Regards
    Simon.
    #159467
    mav12
    thanks again simon i will go for the thermister .
    i had a look at repairs@ but no one came up in my area
    i notice in your profile you cover cheshire do you go as far as liverpool
    if i get stuck
    thanks again
    rob
    #159468
    Simon46
    i dont cover that far but pop up your postcode one of the lads here may cover it.
    Regards
    Simon.
    #159469
    mav12
    bad to worse now compressor wont start at all now think i may have disturbed somrthing taking the back panel out checked the thermal fuses
    they check ok
    checked the connectors for the thermisters
    metered the freezer thermister is about 3.4k at room temp
    would a dodgy freezer thermister stop the compressor working
    if i open the door and power on the compressor starts for a short while then stops
    any ideas
    think it may be a trip to the sales
    thanks
    rob
    #159470
    sputnik
    3.4k sounds about right for kitchen temp in this weather.
    However, it seems the evap thermistor can suffer from an intermittent “thermal fault” at temps at or around below zero.
    See my post here viewtopic.php?f=33&t=64812
    Don’t worry about the compressor / evap fan not coming on as expected. I had both these symptoms with mine. Fixed it for just over a quid. 😉
    #159471
    mav12
    cheers for that sputnik compressor is working ok now after leaving powered off for a while .
    i am unclear on your fix about the resistors in parrallel i assume that would give 2..2 k this is what the evap thermister is showing now so i dont undersatand how it would work unless ive missed something
    thanks
    #159472
    mav12
    doh pennys just dropped i assumed you used two resistors not thermisters
    off to maplins tommorrow
    many thanks
    #159473
    sputnik
    mav12 wrote:cheers for that sputnik compressor is working ok now after leaving powered off for a while .
    thanks
    Heh!
    That was exactly the reading I got with my evap thermistor when it was exhibiting its “fault condition”. It would eventually switch back to normal readings. I am 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure your problem is this thermistor!
    Keep us posted on how you get on!
    #159474
    Simon46
    This is not advisable. Fit the correct part available at http://shop.ukwhitegoods.co.uk/Refriger … istor.html. Job done! 🙂
    Regards
    S.
    #159475
    mav12
    i will fit the proper part was going to try this to see if it was the thermister
    but gets up this morning and fridge is working 2 deg
    freezer -22
    thinking back this all started when i put a large frozen leg of lamb in the fridge to slow thaw was wondering if maybe this fooled the fridge into thinking maybe it was too cold
