Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Hotpoint Mistral Plus FF compressor running constantly
- This topic has 10 replies, 5 voices, and was last updated 19 years, 11 months ago by
jdch.
May 10, 2006 at 9:22 pm #17724
jdch
ParticipantHi:
I have a Hotpoint Mistral Plus FF (model # 8596P), and – following advice from this forum – corrected a temperature problem by replacing the two thermistors.
However, since the repair the compressor seems to be working / running nearly all the time, and so I wonder whether there is a further fault that needs to be corrected.
Please advise
May 10, 2006 at 9:38 pm #175947Simon46
ParticipantRe: Hotpoint Mistral Plus FF compressor running constantly
Have you vacumned the fluff behind front panel? What are the temperatures of fridge and freezer?
Regards
SimonMay 11, 2006 at 5:31 am #175948jdch
Hi Simon:
Yes, I vacuumed the fluff before replacing the thermistors.
The freezer is at a steady -23, which is somewhat lower than the -19 figure that I noticed before the temp problem / replacement of the thermistors.
The fridge is at +4, i.e. exactly on set-point.
Rgds,
John Harrison
May 11, 2006 at 7:11 am #175949Simon46
Frrezer normally runs around -22 mark (colder than minus 18)and fridge is running at setting. is it in a hot room/ trying to freeze lots of food/ door closing correctly/ not run for 24 hrs yet? Temps sound correct anyway.
S.
May 11, 2006 at 7:24 am #175950jdch
Thanks for the reply. In answer to your questions:
– room temperature is normal
– we have not put any new (unfrozen) food in the FF for some time
– both doors are correctly closed
– FF has been running, and displaying this problem, for at least two weeksI would welcome any further ideas.
J
May 31, 2006 at 5:23 pm #175951mikeyman76
ParticipantHotpoint – Mistral FF92 Intermittent display fault
Hi Everyone
I Bought this unreliable unit in 2002 and have just replaced the thermistor P/N 2601683. Its the second on its had fitted. The reason i replaced it is that the display reverts from the usual -22 to +37 and anywhere in between. Unfortunately the fault still intermittently exists. Sometimes switching the whole appliance off and then on again can make the display revert back to displaying -22.
So can anyone tell me if there is a control PCB, where it might be located, the part number and possible price. Im loathed to get a new fridge freezer even though this one has been extremlely bad value for money. I shall certainly never got a Hotpoint one again.
Im an electronic engineer so changing a PCB wont hold any probs for me if you were wondering. Oh before you ask, yes , i have hoovered out the front of the unit and there was hardly any fluff in it.
Any help with this will be gratefully recieved as im getting extremely p****d off with it.
Cheers
Mike
May 31, 2006 at 9:33 pm #175952Dave_Conway
ParticipantRe: Hotpoint – Mistral FF92 Intermittent display fault
mikeyman76 wrote:So can anyone tell me if there is a control PCB
Yes there is. Model (I assume FF92 as per the thread title ?) and serial number please as there’s more than one version of PCB on this one 🙂
June 1, 2006 at 8:54 am #175953mikeyman76
Hi Dave and everyone else
thanks for the speedy response, im at work at the moment so ill post the serial number on here later tonight.
Just noticed after reading a few posts about this model that mine will also revert back to the correct display if you open the fridge door then close it again. So makes me think its more a PCB problem than a thermistor problem. Fingers crossed anyway.
Cheers
Mike
June 1, 2006 at 6:45 pm #175954mikeyman76
Hi everyone
the model number of the item is Hotpoint Mistral FF92P
the serial number of the unit appears to be either 95181570 or 85181570
To confirm: the display displays temperatures all over the range between -22 and +37. But opening the fridge door will make the display change instantly back to -22.
Could this be a faulty control board PCB ?
Mike
June 1, 2006 at 10:43 pm #175955Dave_Conway
mikeyman76 wrote:Could this be a faulty control board PCB ?
Possibly but I would recommend an engineer to be honest as the PCB is £96.60 inc VAT and carriage, part number 2602920 which may prove a costly misdiagnosis 😉
We can certainly order if required, an email to spares@ukwhitegoods.co.uk please 🙂
December 19, 2013 at 10:14 pm #175956rrussell
mikeyman76 wrote:Hi everyone
Mike
Did you resolve this, its exactly the same problem im having, freezer temp fluctuates dramatically.
Condensor heating up, both fans working -
