Re: Hotpoint Mistral plus FF80 temp problem
Open both doors.
Does the front part of the cabinet that seperates the freezer and fridge feel quite hot?
If so the condensor fan has stopped working and your compressor is overheating and cutting out resulting in these kind of temps which used to be a common fault on these.
Also pull away the bottom plinth as there can be a large build up of dust in the intake for the condensor also can cause faults which would just need a hoover out.
