Hotpoint Mistral Plus…….Fixed!
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint Mistral Plus…….Fixed!
  • #28120
    aero
    Sadly as no one here was able to advise me with my cry for help on my earlier post, I decided to combat the problem myself!
    On removing the rear panel I descovered the normal problem of dust and fluff build up. Although the compressor was working the cooling fan was motionless.
    So after a good hoover and clean up:
    First I check the inline fuse, that was OK, checked to see if there was a supply voltage, yes there was.
    Carefully removed the motor (which was a bit tricky, especially removing the fan propeller!) On dismantling the motor I discovered quite a bit of burnt dust inside.
    Once cleaned and re-assembled everything now running ‘tickety boo’
    So if anyone else here wonders why their Mistral Plus is not reaching its normal operating temperatures, Its worth trying this proceedure!
    Hope that helps!
    P.S My occupation is a mechanic, I would have thought that the above task is not that difficult to a good D.I.Y’er
    #216993
    Cyborganna
    Re: Hotpoint Mistral Plus…….Fixed!
    ❗ aero, I’m, in now what? ❗
    Please help – Thank you!!!
