Re: hotpoint mistral plus frost free
You cannot change the temp of the freezer, only the fridge. But to keep the fridge temp low, the freezer also has to work hard so I would increase your fridge temp to 4 or 5 and the freezer temp should adjust accordingly.
Ahh… 😳 I just read again, your freezer is at +22 is that right? Is the Freezer not cold at all then? (or is it just the display that is wrong?) if so you do have a problem, and its engineer time.
