HOTPOINT MISTRAL R134A – Help….
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum HOTPOINT MISTRAL R134A – Help….
  • #14126
    q0j0p
    😯 Need Help… My Hotpoint Mistral 50/50 (frost free) keeps freezing up this in turn blocks the air vents to the fridge section and stops it cooling. The door seals seem fine…. After manual defrost it re-freezes up in about 3 days… Any advice… (I have heard you can set it to defrost frost free manually, by switching the lights on and off a number of times or something similar, is this true) THANKS IN ADVANCE…..
    q0j0p 😳
    #158195
    Re: HOTPOINT MISTRAL R134A – Help….
    Have a read of this:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=108
    for the general outline.
    R134a is the coolant BTW, not the model number – please re-check and post, to allow the fridge lads a better chance of helping you.
    Colin T
    After you defrost the most important thing is to make sure the drain hole is cleared or it will just ice up again!
    Colin
