Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint mistrals
- This topic has 6 replies, 2 voices, and was last updated 22 years ago by
PINKY.
March 22, 2004 at 8:38 am #5256
PINKY
ParticipantMoring chaps,
I have a couple of hotpoint mistral f/freezers with the same fault. Freezer is down to -22 but fridge is +21. fan in freezer working ok and door making contact with switch. your knowledge will be appreciated!Pinky
March 22, 2004 at 1:51 pm #110163PINKY
ParticipantRe: hotpoint mistrals
forgot to post the model number is FF71n
PinkyMarch 22, 2004 at 2:15 pm #110164Dave_Conway
PINKY wrote:Moring chaps,
I have a couple of hotpoint mistral f/freezers with the same fault. Freezer is down to -22 but fridge is +21. fan in freezer working ok and door making contact with switch. your knowledge will be appreciated!I would first of all remove the rear panel in the freezer, it sounds like a possible defrost problem and the ducts between the freezer and fridge are blocked with ice.
PINKY wrote:I also have an older f/freezer 8596p showing E3 fault code, have changed the three thermistors but still has fault.
PinkyE3 is a “Fridge thermistor open circuit” fault, If you have replaced that one then the other things to check are dry joints on the control pcb, faulty new thermistor ? Or possible faulty pcb.
HTH
March 22, 2004 at 2:30 pm #110165PINKY
Cheers Dave, i will check the board for dry joints tonight, it’s my bloody fridge-freezer!!
On the FF71n is there a reason why the air duct should ice up? i’m guessing there must be a flap to control the amount of air up to the fridge?
PinkyMarch 22, 2004 at 2:44 pm #110166Dave_Conway
PINKY wrote:On the FF71n is there a reason why the air duct should ice up?
Yes, a defrost problem in the freezer will cause the ice to build up to such an extent it will block everything. On this model the “flap” in the fridge is a motorised damper which opens and closes to allow less/more air flow from the freezer, may be worth checking this as well.
March 23, 2004 at 11:38 am #110167PINKY
Dave, 5 stars to you! my 8596p with E3 was dry joints and lifted tracks on the board, a few bits of fuse wire later…. hey presto, all is fine.
cheers for advice! 😀
PinkyMarch 23, 2004 at 11:49 am #110168Dave_Conway
PINKY wrote:cheers for advice! 😀
😀 No problem, glad it was that and nothing more serious.
