Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint Module AQ9D692UUKV
- This topic has 14 replies, 6 voices, and was last updated 13 years ago by
A1applianceservice.
March 11, 2013 at 3:18 pm #74501
A1applianceservice
ParticipantHi All,
Having a problem with a Hotpoint Aqualtis washing machine module. The old PCB had blown, causing machine not to drain (pump is fine). I spoke to Hotpoint and ordered a new PCB C00274492 and smart card to program it.The new module C00274492 has a J13 connection on it, whereas the old module didn’t. Has anyone come across this before and know a the modification solution?
Hotpoint didn’t mention there was a modification required when they sold me the part and now will not tell me what modification it requires 😡
Any help would be appreciated
March 11, 2013 at 3:33 pm #391830madangler1
ParticipantRe: Hotpoint Module AQ9D692UUKV
Iv just checked you would just leave it empty, often replacement boards have extra connections than the original is they fit more models.
March 11, 2013 at 5:29 pm #391831A1applianceservice
Thanks for your reply. We tried what you suggested first before posting, but the machine is still faulty. The old module is blown and we have also tested a new pump on the machine. It fills with water, but no pump action. Even checked the pressure switch which is fine. There is no live from the module to pump and no breaks in wires. This is a puzzling one!
March 11, 2013 at 6:40 pm #391832madangler1
Is the motor working fine ? All other parts working ok ?
You programmed with the smart card reader ?
that’s a linear pressure switch model I believe so it won’t pump out with our water in the drum,
March 11, 2013 at 6:54 pm #391833jason1970
Yes – reset the pressure switch. There is a thread on here that will show you how to do it! Caught me the first time!
March 11, 2013 at 6:59 pm #391834Martin
jason1970 wrote:There is a thread on here that will show you how to do it! Caught me the first time!
March 12, 2013 at 4:42 pm #391835A1applianceservice
Hi guys, thanks for the replies and advise. We have done everything mentioned including resetting the pressure switch but it still wont solve the fault. The motor is running fine and the PCB has been programmed successfully. Not getting any pump action from the machine. We have even replaced the pump. any other suggestions?
March 12, 2013 at 4:58 pm #391836Martin
How have you tested the pressure switch by the way? It’s the linear type so I’m curious as to the test method adopted?
March 12, 2013 at 5:00 pm #391837Specialist01269
What caused the pump driver to blow in the 1st place ?
March 12, 2013 at 5:29 pm #391838A1applianceservice
we tested the pressure switch as instructed on the link: viewtopic.php?t=69601#p341650
March 12, 2013 at 6:15 pm #391839Martin
A1applianceservice wrote:we tested the pressure switch as instructed on the link: viewtopic.php?t=69601#p341650
You ‘reset’ the pressure switch using that link, sure. But how did you test the pressure switch beforehand to know that that is not faulty?
March 12, 2013 at 6:43 pm #391840iadom
ModeratorRe: Hotpoint Module AQ9D692UUKV
Just a thought, if the original pcb blew and stopped the pump then it suggests to me that there is a fault in the pump or its associated circuits. If you refitted the new pcb without finding out why the first one blew then the chances are that the new pcb has now also been damaged. 😥
March 12, 2013 at 6:52 pm #391841Specialist01269
That was why i asked what blew the pump driver, looking at the posts on this there’s no mention of it.
Hey Jim: I’ve not come across 1 of these yet, what are they like to work on mate ?
Andy
March 12, 2013 at 7:19 pm #391842iadom
Don’t see many Aqualtis round here full stop TBH, then it’s mainly blocked pumps and drum lifters plus the odd door seal.
March 12, 2013 at 7:24 pm #391843Specialist01269
Cheers Jim: Knowing my luck the only 1 I ever see will have a blown module :eeek: 🙂
Andy
