hotpoint motor
Viewing 15 posts - 1 through 15 (of 15 total)
  • #28548
    abbots
    WM31 1200 spin
    need part number for motor if poss.
    this is the model with the old type door interlock fitted with the pecker on the motor.
    thanks.
    john
    #218755
    Re: hotpoint motor
    We will need the date code on this one John please?
    #218756
    abbots
    Re: hotpoint motor
    hi,
    i cant find the date code on the machine, i presume it was on the door but she has had a replacement door trim as some point.
    are there any other ways of identifying which motor it is?
    john
    #218757
    Re: hotpoint motor
    Can’t you just fit an ARM20 armature and new brushes and be done with it?
    #218758
    abbots
    Re: hotpoint motor
    i wish i could but the field windings are open circuit.
    john
    #218759
    bazza500
    Re: hotpoint motor
    from what I can see on the hotpoint disc is that there are 2 different ones.
    Either a digital motor or an analogue motor.
    The difference seems to be that if your machine has a seperate timer and module then it`s analogue and you need 1604812 and if its digital with combined microprocessor timer and module you need 1604822.
    i would think a wm31 would be digital.
    If you are replacing a GDA motor then you will need a fixing kit as well. 1604976.
    I think 😀
    #218760
    ANDYVIVO
    Re: hotpoint motor
    Hi John
    What colour label is on the old motor?
    Regards Andy
    #218761
    timdowning
    Re: hotpoint motor
    How about the tacho unit. which one is it? small or large?
    #218762
    abbots
    Re: hotpoint motor
    cheers guys,
    i’ll go and have another look at it.
    i would have thought that 1604822 with the new motor terminal block would have done the job,i would assume a machine of this age was a digital motor.
    My main worry is that the motor door pecker may not fit, any one had any problems in the past?
    john
    #218763
    timdowning
    Re: hotpoint motor
    if the pecker is inboard, which it should be, then your ok. 1604822 comes with the inboard stud to which you attach the pecker.
    #218764
    abbots
    Re: hotpoint motor
    thanks guys,
    i’ll still have a look at it tommorrow to confirm all the details.
    1604822 doesn’t come with the stud any more but i should have one knocking around somewhere.
    john
    #218765
    abbots
    Re: hotpoint motor
    right then.
    motor has green label
    large tacho
    motor number 904/1158/05
    timer and module combined. number 904 2412 01
    any ideas guys?
    thanks.
    john
    #218766
    ANDYVIVO
    Re: hotpoint motor
    Hi John
    Green label = digital, so should be 1604822
    Regards Andy
    #218767
    abbots
    Re: hotpoint motor
    great stuff cheers buddy.
    wasn’t sure with it having a big tacho, thanks for that.
    jk
    #218768
    Re: hotpoint motor
    It also has a larger tacho magnet when used with the earlier, large tacho.
    If it has the hybrid timer unit as you say then it is a digital one.
