Hotpoint MSZ702NFD
  • #9014
    JUST BOUGHT ABOVE FRIDGE FREEZER SIDE BY SIDE WITH ICE DISPENSER. Everything is working okay apart from ice dispenser no water going in to it. Have turned it on let it cool down to -19 turned off for ten mins then back on still no ice. Says water must come out at 3kgf/cm2 or more got 9 and a half fluid ounces in ten secs which is more then enough this was from the water on the front door.Do not want to call engineer out if its just something silly. Any ideas???
    #131702
    briansmad
    Re: Hotpoint MSZ702NFD
    Sorry guys just sorted it there is a green test switch below eye level never saw it before. Took ice cube storage case out pressed button ( near left side front under plastic with motor in to turn ice cube tray) until it started moving then left it to spin round then the water came. Should have stated this more clear in manuel sure other people will have same probs with it.
    #131703
    briansmad
    Also while i’m here may as well ask who can supply the cheapest water filter original one that came with hotpoint fridge no copys model number for Water Filter is DD-7098.
    #131704
    Dave should be able to get that for you on spares@ukwhitegoods.co.uk
