hotpoint not fill
  • #68724
    dopper
    its a aq9d69 it was coming up f05 i checked sump hose and pulled a sock out thought that would be it but now its not taking water in but turning as if there was water in, i blow down pswitch hose looks like a new type pswitch on this anyone had this prolem?
    dop
    #372573
    Re: hotpoint not fill
    How far did you tip it back to get the sock out?
    The answer to your problem may lie HERE
    Either in that post or one of the five linked ones at the bottom. 😉
    ……and the shortened version could be HERE? 😀
    #372575
    I thought I would let dopper do a bit of light reading first, then again I could have suggested using the search facility. 😉
    #372576
    dopper
    cheers will give that a go
