Hotpoint NSWE742U WS
  • #101244
    rocker
    I removed a soak from the sump hose today..lent the machine back at an angle to access to sump hose..removed the pump and sump hose..removed the sock…refitted the hose and pump…turned on the machine to test…the pump keeps running ?? won’t stop until I turn the machine off..any advice please.
    checking it might be the pcb ? Its only a couple of years old..cheers John
    #483978
    try putting a few liters of water in the machine
    then select drain
    this can reset the pressure sw water levels
    rocker
    Hi Dave..Did that, it then drains the water and spins..ends cycle and door releases…great…set up a new wash cycle same keeps pumping..?? John
    #483980
    rocker wrote:Hi Dave..Did that, it then drains the water and spins..ends cycle and door releases…great…set up a new wash cycle same keeps pumping..?? John
    assume the pump stopped at the end of the cycle which means the board can turn off the pump
    so I would think its either
    pressure sw or board software
    cant access Hotpoint tech anymore so cant check for known issues
    rocker
    No problem landlord job..I expect new machine…thanks for your help..
