Hotpoint NSWM1146WUK power and screen on but no action F19 error
Home Forums Trade Technical & Spare Parts Forums Hotpoint NSWM1146WUK power and screen on but no action F19 error
  • #103600
    Furhan
    I have a customer this this Hotpoint 11kg washing machine.
    They said it was showing F2, not when I got there.
    It powers up, lock remains on and does nothing, I released the lock and put it on a diagnostic test, I am getting F19 error.
    I have not seen this error before, any ideas?
    #493893
    may have a manual at home will try to think on to look later
    forgot to look but hotpoint site only goes as far as E18
    Hollytree_Technical
    Just had a look at the manual for a similar machine and it says: [TABLE=”border: 1, cellpadding: 1″]
    [TR]
    [TD]F19[/TD]
    [TD]Fan Motor Not Wired
    Fan Motor Driving Triac Short Circuit or Switch Relay Contacts Sticking
    Fan Motor Pin Feedback In Short Circuit With VCC[/TD]
    [TD]- Check efficiency of connector and wiring continuity on the blower
    fan;
    – Check efficiency of connector and wiring continuity on the heating
    element of the blower;
    – Check fan motor is not in short circuit or open circuit;
    – Check fan motor turns freely (it is not blocked partially);
    – Replace main PCB.[/TD]
    [/TR]
    [/TABLE]
    Hope that helps.
    Jem
    #493896
    that’s odd as i don’t think its a washer dryer
    Hollytree_Technical
    nor is the machine that I used for the code but there is what it says in the manual.
    Jem
