Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint – Old Please help
- This topic has 4 replies, 4 voices, and was last updated 14 years, 1 month ago by
LostOut.
February 16, 2012 at 8:11 pm #67952
LostOut
ParticipantGurus,
Before everyone shouts and says throw it on the tip, I have a Hotpoint 9901, by the way it is marvellous when operating, that has been standing idle for a few months during a move. It now over heats and does not progress through the programmes as I remember, take for ever. Has anyone, or does someone know where I can obtain the service manual or schematics book. I don’t really want to throw it out and am sure I can resolve this problem with the manual. It works from rinses etc. but seemed to stay on the wash cycle for an age and the glass front got really hot.Any help would be greatly appreciated and would help to keep my 2 brain cells active
February 16, 2012 at 9:00 pm #369133BigCol78
ParticipantRe: Hotpoint – Old Please help
Had a look on the web but i can’t find a free service manual sorry. The fault sounds like a possible broken wire to the thermistor or a faulty thermistor. If memory serves me correct there are 2 types but i can only find the later type but looks like it comes with the new connections to make it fit. I can’t remember the ohms that you should get through it so someone else with a better memory than me mite be able to help. Thermistor part no. HPT169430 will cost about 30 quid. Hotpoints are also known for faulty timers so check for burnt connections.
Good luck BigCol.
February 16, 2012 at 9:26 pm #369134LostOut
BigCol,
Thanks very much for your prompt reply, I will indeed check the thermistor and the like. Your help is really appreciated I will be sure to report back when I have investigated some more.
February 16, 2012 at 10:58 pm #369135iadom
ModeratorRe: Hotpoint – Old Please help
The manual does not give the thermistor rating. The early thermistor had two small pin type terminals which were prone to failure. The kit always comes with a new connector to cure this problem.
Fault can also be due to PCB or even timer failure, both rather expensive to contemplate at this late stage. 😥
The machine was first introduced in 1986 after all. :eeek:
Unless you live in a hard water area and have done plenty of hot washes its likely that the alloy backplate of the outer drum could be badly corroded by now.
February 17, 2012 at 3:49 pm #369136Martin
iadom wrote:The kit always comes with a new connector to cure this problem.
Certainly is symptomatic of Thermistor problem but hopefully it is just a broken wire connection to it. Looking up the part number of a new Thermistor for you (Pt No: C00169430) I was staggered to realise that they now run to over £28 – £30….. blimey I’ve got 4 (new boxed ones) chucking about in my garage, I must get them up on eBay pretty sharpish! 😯 8)
