The main oven doesn’t respond when I turn the knob. No light, fan or heat. Display doesn’t change. The separate grill and small oven work perfectly, heating and showing the correct display. When I remove the divider between the small and main ovens the extra large oven space also works and displays correctly. Just the main oven appears dead. Any ideas? Thank you.
Re: Hotpoint Openspace Oven Model No. OS 897D C IX/HP
Any ideas about this fault please? Main oven doesn’t respond when turned on but no fault code displayed. Everything else working OK. Any help would be much appreciated. Thanks.
