hotpoint oven BS43W/1
  • #92869
    suedehead1
    hi,
    the oven is overheating and cutting out.
    the cooling fan doesnt come on,
    it works if I bypass the thermostat on top of the oven C00081599.
    I replaced it but it still cuts out any ideas welcome
    thanks.
    #452414
    Re: hotpoint oven BS43W/1
    of course it will work if you bypass the protection stat as the unit is overheating
    think you need to find out why the cooling fan is not operating
    suedehead1
    hi, i didnt by pass the protection switch i bypassed the thermostat which operates the cooling fanthe cooling fan worked so i assume the thermostat was faulty
    #452416
    ok that makes bit more info would have helped. also part number you gave is described as oven protection stat
    https://shop.ukwhitegoods.co.uk/c000815 … thermostat
    and not a fan thermostat which makes things confusing to say the least
    does the cooling fan ever start?
    if you bypass the stat and try it does it still cutout
    if the inside of the oven is getting too surely its the oven stat
    suedehead1
    Cooling can works if I bypass thermostat on top of oven. I assumed part i got was correct as it is open circuit at room temperature. It was late on a Friday when I changed it and I didn’t wait to see if the thermostat worked when oven got hot. Do you have a different number for that thermostat
    #452418
    could just be a bad description. have no access to hotpoint tec or diagrams other members may be able to help
    I would bypass the fan stat and see if it still overheats
    you still did not say if when it overheats it
    1 actually overheats inside the oven so everything will burn
    2 the oven overheat stat cut out switching it off before temp is reached
    suedehead1
    ok thanks I will give it a try
